Author Topic: 16v thermostat?  (Read 1500 times)
kniterider
16v thermostat?
« on: 17 June 2004, 09:33 »
right, youll have to forgive me for sounding thick, but on my 89' 16v mk2 where is the thermostat hiding??
Gaz 8)
Offline GavG60
  • keep my credit cards away from me please :-(
Re:16v thermostat?
« Reply #1 on: 17 June 2004, 10:00 »
pain in the arse mate, changed mine about five months ago.
if you've got power steering then you need to drop the alternator off, then drop the power steering pump to get up under neath the water pump. the thermostat is there behing the elbow pipe going in to the underneath of the water pump.
straight forward but time consuming...... :-\
(changed mine but it turned out I only need to change the heater bypass valve)
kniterider
Re:16v thermostat?
« Reply #2 on: 17 June 2004, 10:08 »
n power steering on mine so ill have a butchers later i thinks!! cheers!!
Gaz 8)
