Author Topic: Ed30 Lowering  (Read 2017 times)
Offline vwtroy
Ed30 Lowering
« on: 06 January 2009, 20:03 »
Hi guy's. So who has lowered there Ed30 then? and by how much? considering speed humps/pot holes.
I'm looking at lowering mine but by how much, what do you guys recomend.
Cheers Troy :undecided:
        ED30 1619/Bluefin/Eibach Sportsline/Jetex Filter/Powerflex dogbone bush.
Offline Hurdy
Re: Ed30 Lowering
« Reply #1 on: 06 January 2009, 20:11 »
Just lowered mine again today. Overall drop is around 40mm from stock. Not slammed totally as there are a few dodgy speed humps scattered around where I live and the car just clears them now.
If you lower too much the geometry can be altered excessively and you may need shorter mounts to stop uneven tyre wear. :smiley:
Seat Leon Cupra Black 290 DSG
Offline Greenouse
Re: Ed30 Lowering
« Reply #2 on: 07 January 2009, 21:17 »
I've got Eibach Sportlines and they lower the car by 25-30mm which for me is spot on as it caused no problems as far as speed bumps/pot holes go and the ride 'comfort' hasn't been compromised either :afro:
Offline vwtroy
Re: Ed30 Lowering
« Reply #3 on: 08 January 2009, 18:51 »
Thank's for the replies, I have ordered the Eibach Sportlines.
Troy
Peskarik
Re: Ed30 Lowering
« Reply #4 on: 11 January 2009, 03:55 »
KW Version 2. 28mm front, 30mm rear. Also 15mm spacers on the back.
Over rough surface, when the car jumps around, I have rubbing on the rear wheels.
My wheels are standard 18-inch Monza II.
Offline candy turbo
Re: Ed30 Lowering
« Reply #5 on: 11 January 2009, 08:31 »
hi mate , are these the only suspension mods you ve done ? just the sport line springs ?  if so have you got a side on pic so i can see the drop ?  cheers
clubsport S no 215
Offline stealthwolf
Re: Ed30 Lowering
« Reply #6 on: 11 January 2009, 11:40 »
Does that mean you can drive straight over speed bumps etc without slowling down (too much)?
Offline Greenouse
Re: Ed30 Lowering
« Reply #7 on: 11 January 2009, 21:10 »
Sorry only just seen this Candy, posted some pics on the 'other' forum for you earlier!  :wink:
BTW, WALK kit purchased and will be going on the car before the POD!  :evil:
Not really Stealth, but I don't have to slow down any more than I used to.
