Author Topic: wheel change  (Read 1192 times)
Offline nelds
  • Now Golfless but owning an Audi still counts
wheel change
« on: 04 January 2009, 21:42 »
im a new MK4 owner and want to put some 17's on, what the correct tyre size i need to keep the rolling size the same
Offline richw911
Re: wheel change
« Reply #1 on: 04 January 2009, 21:43 »
http://www.golfgtiforum.co.uk/index.php?topic=89374.0
* Edit its not in that link its 215/45/17
« Last Edit: 04 January 2009, 21:47 by richw911 »
Offline nelds
Re: wheel change
« Reply #2 on: 04 January 2009, 21:48 »
thanks for that fella, it doesnt show tyre sizes tho..??.....i dont really understand the rest  :grin: it currently has 205/55/16 and i want to put the 17's from my MK3 on but think i'll need to change the tyres
Offline richw911
Re: wheel change
« Reply #3 on: 04 January 2009, 21:52 »
Yeah sorry see the edit ^^^ its 215/45/17  :wink:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: wheel change
« Reply #4 on: 04 January 2009, 22:22 »
You could also get away with 225/45 17's if the wheels are 7.5J x 17.  ;)
If they're 7J x 17, I would personally run 215/45's.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline nelds
Re: wheel change
« Reply #5 on: 04 January 2009, 22:29 »
they have 205/40/17 tyres on at the mo but im guessing these'll throw the speedo and handling out, will the recommended tyre sizes you suggest fit these rims..?
Re: wheel change
« Reply #6 on: 04 January 2009, 23:28 »
Ok.....................................................
**EDIT**  If the wheels are 7J use 215/45, or if they're 7.5J use 225/45.  :afro:
« Last Edit: 04 January 2009, 23:38 by Ivor Mk4 Turbo »
Re: wheel change
« Reply #7 on: 04 January 2009, 23:33 »
Yes 215/45/17's will be fine.
