Author Topic: Impact wrench  (Read 1843 times)
Re: Impact wrench
« Reply #10 on: 03 January 2009, 14:24 »
you arnt thinking of undoing the 19mm 12 point blt in the middle of the crank pulley?  if so dont :P  The crank pulley is held on with the 4 allen bolts.  it might fight you when you try to remove it though, but a puller will make short work of it.
If you wanted to remove the inner crank timing belt sprocket then you need to remove that bolt :)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Impact wrench
« Reply #11 on: 03 January 2009, 17:18 »
your right I didn't need to remove that bolt oh well you learn something new everyday.  :smiley:
