Author Topic: Windscreen Seal...where from?  (Read 2093 times)
VeeDubGTI16v
Re: Windscreen Seal...where from?
« Reply #10 on: 05 January 2009, 11:43 »
Alternatively, you could get a windscreen bonded in as per G60 and Rallye's. Will make the body more rigid too, but you will pay for it!
is it bonded using the same seal as non bonded? or straight to the frame?
« Reply #11 on: 05 January 2009, 12:05 »
its bonded to the metal frame with a filler piece in the gap
VeeDubGTI16v
« Reply #12 on: 05 January 2009, 12:17 »
do you know if the strip is still available from vw? is it reusable? might be worth converting to this as i now have 4 growing stonechips in the windscreen!
« Reply #13 on: 05 January 2009, 15:38 »
apparently this is discontinued, but it seems it should be included with a new screen. but it seems the screen is also discontinued!  its still best to ring VW direct as my copy of ETOS wont show if part numbers have been replaced since the software came out, it can only update prices for the part numbers actually in the program!
Offline golfnut8v
« Reply #14 on: 06 January 2009, 20:32 »
renfrew car breakers have 5 golf mk 2 in stock,hawkhead rd at paisley have 3 in stock,
« Last Edit: 06 January 2009, 21:06 by golfnut8v »
