Author Topic: MKII fan Current  (Read 5010 times)
Offline helliosjon
Re:MKII fan Current
« Reply #10 on: 15 June 2004, 16:08 »
davidhawkins78
thanks for the advice, the blowers work ok so I'll try what youve said.
Awesome gti store sell thermostats and fan switches that trigger at lower temps than the standard ones. Does anyone have these fitted? do they make much difference?
Offline benjam_in
Re:MKII fan Current
« Reply #11 on: 15 June 2004, 16:20 »
could be the first speed setting on ur fan isnt kicking in! and the fan is only starting up when the 2nd threshold is met!
Golf Mk2 Gti 1988
Offline benjam_in
Re:MKII fan Current
« Reply #12 on: 15 June 2004, 16:20 »
presuming its a 2 speed fan that is!
Golf Mk2 Gti 1988
Offline helliosjon
Re:MKII fan Current
« Reply #13 on: 15 June 2004, 16:24 »
how do you tell?
its a 1989 16v.
(if that makes a difference.)
Offline J a m e s
Re:MKII fan Current
« Reply #14 on: 15 June 2004, 16:32 »
my light comes on just as the fan kicks in
Offline benjam_in
Re:MKII fan Current
« Reply #15 on: 15 June 2004, 16:33 »
should be! check to see how many wire are attached to the back of it. if there are two then its a normal fan but if its got three its the fan with two speed settings!
if you wait till you fan kicks in then unplug it and test the connections for power!!! I think on full power they both should have power but im not sure so dont quote me!
Golf Mk2 Gti 1988
Offline helliosjon
Re:MKII fan Current
« Reply #16 on: 15 June 2004, 17:03 »
2 on the fan switch and 2 on the fan
I guess its the basic on then.
I might just stick a couple of tea bags in the expansion tank and have a brew up instead!
Re:MKII fan Current
« Reply #17 on: 15 June 2004, 17:14 »
Ok I would see about getting a different radiator temp sensor which makes the fan kick in at a lower speed.  One thing, does your temp sensor have 2 or 3 pins?
« Last Edit: 15 June 2004, 17:16 by rubjonny »
Offline helliosjon
Re:MKII fan Current
« Reply #18 on: 15 June 2004, 17:22 »
its only got 2 leads on the fan switch.
if I got one with 3 connectors, what would i connect the 3rd  one to?
I only got 2 wires.
Offline helliosjon
Re:MKII fan Current
« Reply #19 on: 15 June 2004, 17:25 »
sorry rubjonny,
I misunderstood what you were saying.
(reading things quickly while at wory you see)
You mean get a 2 connector one that switches at a lower temp?
Like the ones awesome gti sell?
