Author Topic: COOLANT LEAK ISSUE  (Read 13844 times)
Offline Teutonic_Tamer
Re: COOLANT LEAK ISSUE
« Reply #10 on: 03 February 2009, 17:39 »
ive been getting the same problem having to keep top up the coolant, its ben in to a dealer once and they said they couldnt find a problem!? so im taking it to anougher dealer to see what they can do maybe point them in this direction?
mitch
A wise move.
At the end of the day, cooling systems on modern cars are effectively 'sealed', so they shouldn't need any topping up.
However, just a note of caution, on some cars, some cooling systems will actually find their own level, and this may actually be below the minimum.  By all means, top it up with the correct coolant additive mix to the max level, but then monitor it over a week or so.  If it progressively drops a little each day, but then appears to stabilise at a certain level - then just leave it at that - even if it is below the minimum.  If it completely empties the expansion bottle, then obviously further investigation is required.
I feel like a homo
Offline mitchGTI
  • MK5 GTI
« Reply #11 on: 03 February 2009, 17:46 »
well ive had to top up have ive had the red warnong light on the dash 3 times now so then went to dealer and they said they couldnt find a fault? was abit wierd altho since it went in about a week ago its been fine? im getting abit annoyed with it all now tho
mitch
GTi gone! : ( replaced with....
Metalic black S3.... Standard!.... For now....
Offline AlanD
  • MK5 2.0T 16v
« Reply #12 on: 03 February 2009, 18:14 »
Sounds identical to the problem I had. Kept on getting the low coolant warning. How long is there between filling it up and getting the low level warnings?
Offline mitchGTI
  • MK5 GTI
« Reply #13 on: 03 February 2009, 18:24 »
its every month or so maybe longer? ive only had the car since october and had to sort it out about 4-5 times!
Offline AlanD
  • MK5 2.0T 16v
« Reply #14 on: 03 February 2009, 18:30 »
Yep, sounds just the same as mine. My one was lasting a month or so, maybe a tad longer before running out. Print this page out and take it to the dealers along with a copy of that invoice I posted and see what he says . . . . ?
Offline winrya
« Reply #15 on: 19 February 2009, 20:50 »
Just to update guys, my car was suffering this problem.  My specialist could see staining on the side of the engine where the Flange(?) is.  They ordered a plastic part which looked like the pipes were connected to but when they took it off it was perfectly fine and it was just a rubber O ring that had been flattened and as such was leaking tiny amounts of coolant.  There was another O ring which he replaced while he was there but parts cost 91p each lol.  Touch wood it has been perfect since.  Seemed a real struggle to get to but the place is superb.  Cost of fixing this fault and replacing the DV valve to revision G at VW - 300 pound, my specialist 151 pound all in :smiley:
Offline RedRobin
« Reply #16 on: 03 March 2009, 15:36 »
I have a look under my bonnet about once a week (well, it's just an excuse to handle all that luverly lightweight black shiny carbonfibre :smug:) and I noticed my coolant level had suddenly dropped about 3/4 of an inch one morning after a freezing cold night (unheated garage).
I phoned my friendly dealer and he said top it up with a bit of water to a 'mark' and check it every day and come back to him if it continued to lose.
It's happened once more but only during that very cold snow spell we had and without any dashboard warnings being activated.
While having the 60k miles cambelt kit change, they pressure tested the coolant line and found no leakage or problem but have replaced the coolant (£21.36 for 3 units).
I would post a pic of my coolant liquid but this is more interesting :evil: : -
Offline DanoGTI
« Reply #17 on: 18 April 2009, 09:09 »
Are there any updates on this topic - have the people's levels sorted out?
Just something I'm keeping an eye on for when I get mine :)
Dan
DA Productions
The fine art of diplomacy is telling somebody to "fcuk off" in such a way that they actually look forward to the journey....
Offline AlanD
  • MK5 2.0T 16v
« Reply #18 on: 18 April 2009, 11:13 »
Since having my flange and bits replaced by VW mine has been fine.
Offline RedRobin
« Reply #19 on: 18 April 2009, 16:58 »
.... :shocked: Your "flange and bits"!!? :shocked: "replaced"!? :shocked:
Well, Alana, you must be a true VW fanatic to go that far :evil:
