Author Topic: RON 98 Petrol  (Read 3302 times)
Offline Gambit
Re:RON 98 Petrol
« Reply #10 on: 23 June 2004, 13:25 »
your timing is out
the 16v ECU can only advance/retard so much
Offline Gambit
Re:RON 98 Petrol
« Reply #11 on: 23 June 2004, 13:38 »
id stick to one type of fuel and set the timing from that - then your sorted
i found running my car on LRP, BP Ultimate & Shell SUL caused all sorts of timing probs even though they are all 97RON
so now i just use LRP as its the cheapest, set the timing and left it at that - hasnt skipped a beat since
vwsystems
Re:RON 98 Petrol
« Reply #12 on: 27 June 2004, 01:07 »
i dont know if i ve said this but
the octane rating in petrol if not used quickly..... ie optimax not many people use it, the rating drops if its stored too long...... how long this is i dont know.....
but thats probibly the case........
old optimax will have less octane then the fresh daily delivered supermarket petrol!
i could be wrong but if timmings bang on then i guess this is the case as if there was something wrong with your hall sender or ignition module then it would show up on the supermarket petrol...........
« Last Edit: 27 June 2004, 01:08 by vwsystems »
