Author Topic: MK4 GTI Tips & Tricks  (Read 206933 times)
Offline ben1.8T
Re: MK4 GTI Tips & Tricks
« Reply #20 on: 02 January 2009, 11:37 »
The window open and close doesnt work on mine? Does on my dads TT  :sad:
Should work from the key????  :undecided:
It didnt work from the key mate?  :sad:
You have to hold the key in the lock for few secs  :undecided:
What so hold it in the lock for a few seconds and push the button?
« Last Edit: 02 January 2009, 11:38 by Rhyso »
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline Rhyso
« Reply #21 on: 02 January 2009, 11:39 »
no hold the key in the locked position - takes a few seconds before the windows start going up and you have to hold the key there until the windows are fully closed
Offline ben1.8T
« Reply #22 on: 02 January 2009, 11:56 »
Will I be able to open and close them by remote then?
Offline Rhyso
« Reply #23 on: 02 January 2009, 11:59 »
no!
not unless you buy one of these
http://www.vagproducts.co.uk/kvw.html
Offline ben1.8T
« Reply #24 on: 02 January 2009, 12:01 »
Oh I thought you could do it remotely my dad can on his TT  :sad:
Offline Rhyso
« Reply #25 on: 02 January 2009, 12:04 »
the Golf's CCM isn't programmed to do that - it can be re-programmed but you need the correct lead and software - VAGCOM and VAG TACHO WILL NOT do it
Offline ben1.8T
« Reply #26 on: 02 January 2009, 12:07 »
Oh I see cool cheers matey ill just have to not be lazy and shut them the normal way then  :cry: :smiley:
Offline Rhyso
« Reply #27 on: 02 January 2009, 12:10 »
yep - in fact it works out just as quick to do it the normal way - i got the auto windows module but you can't stop the windows going up so no good for when i got my dog in the car and end up using the key in the lock anyway  :sad:
Offline ben1.8T
« Reply #28 on: 02 January 2009, 12:25 »
Pain in the ass then mate. Cheers for the help mate.  :smiley:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #29 on: 07 January 2009, 15:37 »
Try the other door lock, Ben.  My O/S lock is foobarred.  Window will only open on that side (key in door method), but works both ways on the N/S.  ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
