Author Topic: dai-cymru - 2.0 to 1.8T swap  (Read 35069 times)
Offline dai-cymru
  • 1989 MK2 16V
Re: dai-cymru - 2.0 to 1.8T swap
« Reply #10 on: 15 January 2009, 18:54 »
Offline dai-cymru
  • 1989 MK2 16V
« Reply #11 on: 20 January 2009, 13:47 »
DOH!!!!! cant get the car running the immobiliser is causing me a headache i have swapped the ecu clocks ignition barrel and keys over and the immobilser still cuts in and cuts engine out, so anyone know how to sort this  :sad:
Offline ben1.8T
« Reply #12 on: 20 January 2009, 14:21 »
Im sure R-Tec Nick will know you got it in there quick enough though mate  :cool:
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #13 on: 22 January 2009, 01:58 »
funnily enough rhyso has spoken to nick and my ecu is off to his magic hands to sort out so hopefully by the weekend it will be running!
 :smiley:
Offline ben1.8T
« Reply #14 on: 22 January 2009, 10:11 »
Result fingers crossed then mate  :cool:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #15 on: 24 January 2009, 21:17 »
no pics but fitted the intercooler today and bob split the 2.0 loom and wired in the missing plug for the secondary air pump i also bled the brakes and clutch today  :smiley: also removed the exhaust from the donor (had to cut the rear off as still original and was running over the axle) ECU is hopefully back on monday thanks Nick :afro:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #16 on: 27 January 2009, 11:02 »
ECU came back yesterday but the car still wont run dont know whats wrong with it, seems the immobiliser is still cutting in for some reason  :cry: :cry:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #17 on: 02 February 2009, 18:47 »
 :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool:
had the ECU, clocks and keys back from a guy on UKMKiv's today Thanks ARD he recoded all the gear for me, i put it back in the car today and with clenched butt cheeks (was so worried it wouldnt work cos of the problems i have had) and low and be hold
IT'S RUNNING  :cool:
also big thanks to rhys for spending hours searching the net for soloutions and posting all my stuff to ard to sort out.
also did i say
IT'S RUNNING  :grin:
Offline dai-cymru
  • 1989 MK2 16V
« Reply #18 on: 09 February 2009, 11:57 »
righto after stripping the shell and my front drive looking like a scrap yard it was time to say goodbye to the turbo shell forever
bet you havent seen a flying mk 4 before !!!
Offline dai-cymru
  • 1989 MK2 16V
« Reply #19 on: 10 March 2009, 22:12 »
Right bit of a update, Got new CCM and fitted it, still didnt work spoke to ARD over on ukmiv's and he sussed it out, i fitted the immob 2 clocks and my car is immob 3  :sad: so got ARD to recode my immob 3 clocks to work with the immobilser, This guy is a legend he put auto windows on and miles to empty on the clocks he knows the MK4's electrical systems so well so big cheers ARD :afro:  and big cheers to rhyso and his vagcom for coding it all in so i can now disable my alarm open my windows start the car and adjust my mirrors all with one key  :smug:
also fitted the tip today bit dissappointed  that it has a extra hole thats not needed (so much for engine specific) so looks a bit pants with a bolt in it, i did put a shiny cap bolt in it to make it look a bit better, but the tip hasnt solved the running prob  :cry: :cry:
