Author Topic: clutch release mechanism  (Read 1846 times)
Re: clutch release mechanism
« Reply #10 on: 02 January 2009, 09:40 »
yeah the end cap is removable but it should also have that green plate, it might have been painted over if the box was refurbed.  Dont take the end cap off if you can help it, you'll loose most of uyour oil and also theres a selector rod that sticks out here, if you remove it the box needs stripping down to refit.  no point risking that when you can do all the repairs thru the green cap!  just make sure you buy a newun.
Offline shadymofo
« Reply #11 on: 04 January 2009, 16:22 »
i found the green end cap not long got back home after leavin her stood for nearly 2 weeks,waitin 4 parts 2 arrive now
Offline shadymofo
« Reply #12 on: 11 January 2009, 16:00 »
just a simple question the clutch cable is not connected to the release lever and when i push the pedal in it stays on the floor could it be the self adjust mech thats failed or the full cable
Offline sidecarphil
« Reply #13 on: 11 January 2009, 18:07 »
it only returns vai the pressure of the clutch
so it will stay on the floor  :tongue:
