Author Topic: Gearbox Question  (Read 7940 times)
Offline tonsofun
Gearbox Question
« on: 15 December 2008, 19:20 »
i have a vw scirocco, with a 2.0 8v passat engine which untill now has been using a mk2 golf gti (8v) gearbox....however its foooked!
What other gearbox's are the same fitment? i know they pretty much all fit to the block, but which will have the same input shaft size and spline (so it will fit my clutch)?
Any help will be great, and if anyone has what i need near cambridge let me know!
Mark
2 Mk2's, both in bits, 2 Rocco's soon to become 1, and a Polo 1.3.....
The polo is the only car with MOT and in working order...Doh!!
Offline danny_p
Re: Gearbox Question
« Reply #1 on: 16 December 2008, 00:17 »
any  mk2 8valve  020 series box will  fit your clutch.
mk2 16v  and mk3 8 valve boxes have the larger shaft
all the VW's have gone bar 1.
« Reply #2 on: 16 December 2008, 10:56 »
make sure its a MK2 GTI box though, non-GTI has smaller 90mm driveshaft flanges.  Though you can swap the larger 100mm GTI ones on, this is an extra pain in the arse you could do without I expect  :grin:
Later cabs and sciroccos have the 100mm shafts as well.
The MK3 2.0 and MK2 16v boxes can be fitted if you put a 16v friction disc on.
Offline danny_p
« Reply #3 on: 16 December 2008, 14:35 »
or a mk3 friction disk
Offline tonsofun
« Reply #4 on: 16 December 2008, 19:52 »
wicked, cheers for that, goin to have a go at fitting a rocco 8v box, (and the smaller shafts that go with as i have it laying around, unless anyone has the golf one to hand???
« Reply #5 on: 17 December 2008, 11:11 »
being a rocco box it may have the larger shaft flanges already :)
Offline tonsofun
« Reply #6 on: 18 December 2008, 20:15 »
rocco one has smaller shafts...and looking at the state of my clutch i think i'm going to change it, was wondering if this would fit? don't know the box codes, don't know if this is cable change, and weather i can convert it to fit my car (will probably need the clutch to match, but while its in bits i think i may aswell do the best i can for it) i think you change change the selector on the car to take cable change one!???
hope that makes sense
Mark
Offline tonsofun
« Reply #7 on: 18 December 2008, 20:21 »
Offline danny_p
« Reply #8 on: 18 December 2008, 20:58 »
you need
cabel change selector & cabels
flywheel  228mm
clutch  228mm
seat 16v clutch actuator
seat 16v clutch cable
seat 16v gear box mounting bracket ( ideal )
i'm sure someone will provide partnumbers
then it's just bolt up
Offline tonsofun
« Reply #9 on: 18 December 2008, 22:00 »
what is that flywheel and clutch off of? and what 16v seat are the parts off? just so i can price it all up before buying the box!?
cheers
oh and whats the mount for? will the standard rocco ones not fit??
