Author Topic: Water Leaking in to footwell on passanger side  (Read 2071 times)
Offline gti8vsheffield
« on: 02 January 2008, 17:59 »
Hi can anyone help me mk4 gti water in footwell is it the pollen filter gasket ? or the plenehm cover . cheers .
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
Re: Water Leaking in to footwell on passanger side
« Reply #1 on: 02 January 2008, 21:40 »
Will be watching this thread closely as both mine and me mams Golf has similar symptoms. I thought it was just a leaky door seal.
Offline barrett84
« Reply #2 on: 03 January 2008, 11:00 »
Hi all,
I had this issue after i replaced my front left wiper motor and i had knocked the pollen filter which caused water in the passenger footwell, I got a freind to check it over and replace it and wahoo no leek! hope this helps.
Offline saul79
« Reply #3 on: 03 January 2008, 21:10 »
pollen filter housing and the window regs are a common problem on mk4s for water leaks ,check the edge off the door card for wetness,the seal around the reg gets wet and soak anymore water up so it deteriates and leaks in the car :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline gsn1978
« Reply #4 on: 08 January 2008, 15:21 »
Guys i have this too, its doing my head in, my floor mat froze to the carpet the other day in the big freeze!! so ive got a panel beater / leeks man looking at it this weekend, ill let yous know what he comes up with...
Cheers, George.... 1.8 GTIt and loving it!!
Offline Lennon
« Reply #5 on: 08 January 2008, 19:28 »
I get this in my rear passenger footwell... its right in the middle away from the door so I don't think it can be coming through there.
Causes monster condensation some days  :sad:
Offline gsn1978
« Reply #6 on: 09 January 2008, 10:34 »
I am lead to beleve the golf has a metal shower curtin behind the door card sealed with fome tape (god my spellings shocking lol) and at times this can perish and cause the leaks, also in some exstream cases it can come through the bolt, can anyone confirm the shower curtin and folm tape storys i think we could have a winner it thats the case.......
Offline saul79
« Reply #7 on: 09 January 2008, 18:48 »
thats what i'm on about  :smiley:replaced a lot off em at vw .9 out of ten times it was the windor regs with the duff seal :smiley:
