Author Topic: climate control problem?  (Read 3449 times)
Offline Hurdy
Re: climate control problem?
« Reply #10 on: 13 December 2007, 16:41 »
Mine is left on Auto and does the slow start up as it should. If you use the front heater function it will immediately go to full fan whether the air is hot or cold. This is the only way I know how to induce the full fan with cold air. Does your car blow the cold air at you or the windscreen? Methinks that you may have an error linking in with the front windscreen blower function if it blows at the windscreen.
Seat Leon Cupra Black 290 DSG
Offline MarkD
« Reply #11 on: 13 December 2007, 16:55 »
thanks for your posts.
Front heater function?
Mine is set to 'AUTO' and 22 Deg. All the direction indicators (ie footwells etc) are off. Doesnt matter if ECON is on or off. I immediately get the fan speed on about 4 LEDs and (very) cold air blows out of the windscreen vent, the centre vents and the side vents.
A comment on an earlier post referred to setting the system to AUTO and the fan will be slow (or off) and increase as the cars ability to deliver hot air increases. That i believe is correct but not what my car does ... and it sounds like a few others dont get this either
Offline Bustwell
« Reply #12 on: 14 December 2007, 15:49 »
Thats what happens in my GTI and S3 for that matter
2005 Golf GTI DSG, Steel Grey
2001 Audi S3 for the rainy season (that'll be all year then)
Offline maxamus
« Reply #13 on: 14 December 2007, 16:03 »
How good is the AUTO and what the hell does it do?
Offline illyun
« Reply #14 on: 14 December 2007, 16:13 »
LOL you've never used it?  :grin: :grin: :grin: :grin: :grin: :grin: :grin:
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline illyun
« Reply #15 on: 14 December 2007, 16:16 »
I check mine yesterday. When the car is cold you don't get much air with the auto on even if your increase the temp setting  to 25C.  You have to manually increase the fan speed and as soon as Auto is turned on again, the fan speed goes down until the car warms up and it gradually increases. So you've got a problem.
Offline maxamus
« Reply #16 on: 14 December 2007, 16:20 »
ye i've never used it. Does that set the cabin temp and fan speed itself and then regulates it or somit?
i, well these days atleast, have it on 29.5*C. What would auto do for me?
