Did you let the carb cleaner dry out or blow it out with air?
Are the hose connections tight for all vac hoses?
I'd set it up again for fueling with rubjonnys guide, then maybe donor a working isv. Sometimes cleaning it with petrol can ruin the rubber seals in the isv, if you leave brake cleaner in it for too long it can do the same.
