Author Topic: should i have ppower steering  (Read 2639 times)
Leon R
Re: should i have ppower steering
« Reply #10 on: 25 October 2007, 22:18 »
p.s test the thermostat before you put it in, i had to do it all again coz had a cack one from GSF!
G
Second that! Stick it in hot water and see it open.
Another reason for hot air not blowing is that the heater matrix bypass valves may be blocked. These were installed as a recall to prevent the heater matrix going pow and unloading hot coolant over the passenger.
I'm not too sure how to unblock them tho, maybe a reverse flush or a new set?
it takes a long time sometimes maybe drive for 30 mins before temp gauge goes up to nearly halfway. then when i turn th fan on it blows warmish for bout 20 secs. coolant lvel is fine as car just been serviced
This sounds like your thermostat is stuck open or is lazy at opening. By running cool you are using more fuel too so it might be very well worth changing it as they are only about £4 and you need a new Seal too.
Offline ginga
« Reply #11 on: 26 October 2007, 06:48 »
thanks guys i'll get on to that this weekend and let you know. hope it works, gettin a bit nippy now!
Offline meg1980
« Reply #12 on: 26 October 2007, 16:08 »
the other problem might be the valve inline to the heater matrix try changing that as that is a quick fix happened to me no hot air in the car change valve put antifreeze in bled it up,bingo.
i was told the 020 rod box was supposed to be a strong box,how wrong are they 5 and counting on my mk2. Hopefully the quaiffe box will last.
Offline ginga
« Reply #13 on: 27 October 2007, 18:29 »
hi! today i replaced the stat, unblocked some pipes goin through to the heater but no warm air. is there anything in particular i need to flush it through with?
Offline ginga
« Reply #14 on: 27 October 2007, 18:53 »
should i just bypass the valves?
Offline takethefifth
« Reply #15 on: 27 October 2007, 21:42 »
If you still have the bypass valves i would say bypass the bypass!  Did it on mine last weekend and it's like being on a tropical island in my car now!
Nothing particular to flush it through with, a hosepipe will do the trick.
