Author Topic: Questions on achieving more BHP from 1.8T  (Read 2827 times)
Offline topher
  • Administrator
  • fully functioning
Re: Questions on achieving more BHP from 1.8T
« Reply #10 on: 16 January 2007, 20:53 »
revo dont do a map for a k03s on AGU's.. you'll need a custom map, i run standard brakes and they're fine for the way i drive
Offline sambo
« Reply #11 on: 16 January 2007, 21:08 »
Right, that may be a bit of a problem as living in devon the only re map i know of close to me is revo...
TBH i don't drive like boy racer anyway, infact i don't really use the car on a daily basis, just on the weekends only put 3000 on the clock last year..
May leave the brakes then, where am i likely to be able to get a custom re map from?
Thanks again topher   :wink:
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline sambo
« Reply #12 on: 17 January 2007, 13:32 »
Found a K04, manifold, custom down pipe with bigger injectors and all relevent pipework for £550 although sounds a bit pricey to me maybe, If the downpipe is just a stock modified, any ideas what injectors they will be using?
Would then need a FMIC i take it? have seen some 'no make' intercoolers on ebay for £150 but with no pipework
Or what are people's opinions on the best kit's. I have seen the neuspeed kit on awesomegti but states will not fit my car (mines 1999 says 2000-on)
Thanks, Sam
« Last Edit: 17 January 2007, 13:34 by sambo »
Sam
Offline micko
« Reply #13 on: 22 January 2007, 21:22 »
hey sambo, where did you find the ko4 turbo, manifold and downpipe for £550...
in denmark i have to pay £900 only for the ko4 turbo and the manifold is about £3-400...
