Author Topic: trouble starting when engine's warm  (Read 1048 times)
Offline gtitdi
« on: 16 January 2007, 21:53 »
hi, just wondering if anyone has any ideas about this... I have a 1.6 Mk3 CL, when the engine is cold it always starts on the first turn straight away. When the engine is warm it takes a good second or more of turning over before it starts. What could cause this?
Thanks in advance
Offline boneybradley
  • Back in a Mk3...
Re: trouble starting when engine's warm
« Reply #1 on: 16 January 2007, 22:20 »
Temp sensor.......Work's the gauge and also ecu, cost about £10 and they take 10 minutes to fit
Offline gtitdi
« Reply #2 on: 16 January 2007, 22:49 »
Where is it located and how are they replaced?
  • Back in a Mk3...
« Reply #3 on: 16 January 2007, 23:08 »
This show's my ady engine but they are in a similar place on all mk3's...one point just check the colour of your's as there is a few differnt one's... and to fit you just un clip the wire and they pull out
Offline gtitdi
« Reply #4 on: 17 January 2007, 12:53 »
Thanks for that, I'll have a look.
Recently, the temp gauge on the dash has been a bit all over the place, could this be due to the faulty sensor or could it be the thermostat?
  • Back in a Mk3...
« Reply #5 on: 17 January 2007, 13:11 »
That sound's like a faulty temp sensor or lose wiring...And on the pic i have refered to this as ecu temp sensor and when they fail the ecu think's the engine is cold and then add's more fuel (making your engine hard to start)
