Author Topic: Erractic Idleing Problem  (Read 1004 times)
Offline Martz
« on: 05 January 2007, 11:02 »
Hi
I have posted this here in the hope that this will be seen by more people on the site and receive ideas.
The problem stated yesterday on the Rallye. I got home and parked up with no problems. Went back out about 1/2 hour later and it was running really funny. The car was revving by itself but only upto 2.5k revs. This stopped when I turned the steering wheel to one side, but stated again when I stopped in traffic. The car pulls fine when moving and goes with no problems.
I have recently installed a BBM solid engine mount and this does cause more vibration but perfomance is much improved. I have a feeling this problem is down to a vacuum pipe or a pipe loose in the engine bay.
Can anyone shed some light so I can try to remedy this little problem at lunchtime.
Thanks
Martz :cool:
Offline gibby
Re: Erractic Idleing Problem
« Reply #1 on: 05 January 2007, 13:41 »
I don't know why Martz but just seeing the title of this thread and before reading it I was thinking that it may be some sort of air leak. :undecided:
......now officially dubless.
Offline Len
« Reply #2 on: 05 January 2007, 13:44 »
Yes air leak or maybe an intermitent blockage.
www.sas.org.uk
www.the-ace.org.uk
Offline Martz
« Reply #3 on: 05 January 2007, 13:54 »
Had a quick look but can't see anything obvious. Bloody car.
There is a brown wire with a connector hanging loose though. Can see where it attaches to.
I do think air leak to tbh.
Offline clipperjay
« Reply #4 on: 05 January 2007, 16:50 »
Martz you checked and de coked your ISV?
The only other thing apart from vacum leaks is there is a O2 sensor that can play up or something is lose from the throttle body on top where the gas cable is link to I've heard sometimes there is a screw that controls idle near the throttle cables that can sheer off or drop out check if its still there, check how lose the cable is?
A fellow Rallye owner had a bad blue coolant sensor go, which controls the timing I sugest that you take the wires of the ISV and then the Collant sensor and see what difference it will make mate.
