Author Topic: LIL Heads up.....  (Read 1260 times)
Offline Hammy
LIL Heads up.....
« on: 09 April 2004, 22:24 »
Just fixed the starting problem on the old girl which has given me a headache for a few months now.
She has struggled on cold starting and the cranking has been slow to say the least.  I thought it could have been a charging problem but the battery never went flat once.  Problem I did find out was that if the voltage went too low it would reset the MFA and loose both the clock and fuel economy !! *groans*
Well the car wouldn't start on Weds, so stripped her down this morning.  Bottom line was that the starter motor was grubby and the spline coated in dry grease.  This I believe was causing the 'dog' to stick and not engage the flywheel.  Cleaned and checked the spinout against the engine before refitting.  Bloomin' nora, this was a pig to do getting the three bolts aligned but eventually she was bolted home.
Car started but again reluctantly.  So I decided to check the earth lead.  Cleaned the chassis contact with a wire brush on a drill and sandpaper.  Also did the same on the engine but still the same.
Over comes my bruv and he says hang on a mo, give this a go.... Heads into the garage and comes out with a length of 10mm earth mains cable .  We attach this from the negative on the battery to the engine and sod me.... VROOM !!!
Kicks over like a rutting sperm whale !!
Well there ya have it.. If you have starting issues check your earth connections and bypass the chassis and link direct to the engine :)
Enjoy !!
Paul :)
Offline Gozza
Re: LIL Heads up.....
« Reply #1 on: 14 October 2006, 14:49 »
Top tip there, think I will give this a go once I sort my new starter motor as it does not start to great at th moment. Any tips on cleaning/fixing a starter motor ?
Thanks
Offline Davo13
« Reply #2 on: 14 October 2006, 18:12 »
Thanks
Don't know about fixing one, but a re-conditioned unit with warranty will set you back between 70-80 quid.
I got one a few weeks ago from my local motor spares place.  It was re-conditioned by Quinton Hazel Automotive.
Veedubgt18v
« Reply #3 on: 14 October 2006, 18:16 »
just get a recon one from vw they are about the same price with a £20 refundable surcharge
Offline keithyboy
« Reply #4 on: 14 October 2006, 20:50 »
If you're having trouble with it cranking slow and you're sure the batt is good get attach a jump lead from a handy metal point on the engine to - on the battery. If it spins faster it's the earth.
If you lose the earth lead for any reason, the engine will try to earth by any metal contact it can. This includes things like accelerator cables. It can cause the plastic outer to melt too.
Wrong wheels and mine's Calypso not snot but it's close enough
Offline Gozza
« Reply #5 on: 15 October 2006, 14:38 »
Bought one from Ebay for £18 inc postage, looks in good condition too. Not bad considering they want £70 plus VAT new.
I shall see how the old girl starts once I fit it and will also try the earth as suggested.
Thanks all :)
