Author Topic: Now my window regulator's playing up!  (Read 1262 times)
Offline Zayd
« on: 14 October 2006, 16:44 »
It appears that my driver window had the common fault as most others.  The only problem is that the repairer may have cross wired the unit because when I press down with light pressure the window doesn't open.  However if I press hard then the window goes down until fully open.  When the window's half open and I press up with light pressure the window actually goes down.
Looks like there's a gremlin in there somewhere.
Turbocharged and liking it...
Offline topher
  • Administrator
  • fully functioning
Re: Now my window regulator's playing up!
« Reply #1 on: 14 October 2006, 17:15 »
Sounds like the switch is knackered. There's only one plug to the switch unit and it only goes on one way.
Offline richandhazel
« Reply #2 on: 14 October 2006, 17:57 »
Mine does exactly the same. I've learnt to live with it, Vacom doesn't throw any codes up
