Author Topic: short shift for 1.8 driver?  (Read 1141 times)
Offline pottsy007
« on: 26 September 2006, 16:18 »
Hi all, can you get a short shift for 1.8 driver? if so how much n where from? Also does anyone know of any more decent tuning tips for my 1.8? cheers
Judderi
Re: short shift for 1.8 driver?
« Reply #1 on: 27 September 2006, 08:44 »
If the linkage is the same as a gti then just buy a gti kit.
As for tuning i think the best mod is to fit a gti camshaft and exhaust manifold + exhaust.
« Reply #2 on: 27 September 2006, 14:24 »
1.8 linkage is almost the same as a MK2 Golf linkage, so you'll need a MK2 kit.  I think the early MK3 GTIs also had rod change like yours, so a kit for these models will also fit, basically you're after a rod change kit :)
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 27 September 2006, 21:19 »
I had a 1.8driver before my gti and I replaced the linkages,clutch arm etc...The driver has an 020 gearbox (green gearbox cap) which apart from ratio's is the same as a Gti 020 box and I have swapped all the new part's from the driver to my gti.. (both car's were 1995 car's driver 1.8abs engine and gti8v ady engine). regarding engine tuning, The driver had a 90bhp engine with single point injection and a good quality (gti8v) full exhaust and a panel filter is really the only option's as the s.p.i is like an electronic carb/1 lonesome injector thing and is very limited in tuning!!
