Author Topic: Power boost valve  (Read 1636 times)
Offline boyob32
  • 1.8T
Power boost valve
« on: 12 September 2006, 09:40 »
I'm thinking of fitting one of these to my gti.
Is it worth doing? and also is it easy enough to fit??
cheers
Offline ryushi
Re: Power boost valve
« Reply #1 on: 12 September 2006, 11:47 »
Is that the FSE power boost valve?
I put one on my old Uno Turbo, it replaced the standard fuel pressure regulator, it had an adjuster on it which I had to fiddle with - when I first went for a drive the performance was quite bad and I had to adjust it a few times until I got to a point where I thought it was good enough.
The car was later setup by a proper tuner - I think he adjusted it properly as the car felt much more powerful when he was finished.
So no, I dont know if they are any good (I have a suspision they are crap)  but if you do get one I would reccomend getting a tuner at a rolling road to set it up for you.
Offline boyob32
  • 1.8T
« Reply #2 on: 13 September 2006, 13:55 »
thanks for that   :smiley:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 13 September 2006, 14:10 »
Absolute garbage, mate.  Had one on my old Clio 16v & couldn't wait to get the damn thing off.  Drove dog rough with it on! :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline boyob32
  • 1.8T
« Reply #4 on: 13 September 2006, 14:28 »
thats decided then..!!
cheers was v close to parting with my money....
