Author Topic: 16v oil buzzer  (Read 781 times)
Offline Diluxe
16v oil buzzer
« on: 08 April 2006, 18:15 »
Hi all,
oil buzzer starts buzzing when i go round a bend at speed, however I've checked the oil and seem to have an adequate level in the engine, is my pump on the way out ,,,,,,,,,,, if so would i have noticed by now, or is it the buzzer and where can i find it to replace/check it.
cheers
p.s. can anyone recommend anyone in the southampton area on 16engine work?
1997 16V
Offline Agreeable Slick
  • Unit
Offline Diluxe
Re: 16v oil buzzer
« Reply #2 on: 09 April 2006, 12:24 »
yeah i read that one slick, but it doesnt actually say where the oil switch is, does the pump run of the cam/accessory belt?
1997 16V
Re: 16v oil buzzer
« Reply #3 on: 09 April 2006, 15:52 »
both low & high pressure switches are on top of the oil filter housing.  The high pressure one is the white sensor with the yellow wire, and the low pressure is the black/brown with a blue wire.
