Author Topic: Golf Gti Mk2 PB Engine Code Idling Far Too High....HELP PLEASE!!!!!  (Read 7075 times)
Offline Organisys
  • Old and Slow...
check the switch is actually switching using a multimeter if you can, mine clicks but the switch contacts must be so worn, sometimes it doesn't work.
Offline TwistedAspect
  • '89 Gti 8V - Diamond Black (RIP)
You don't mean Murrays in Hatfiled do you? Bought a blue temp sender from there and it packed up after a few months. Everything else I've got from there has been fine though.
No...It is Murray Volkswagon in Plymouth.....very helpful guys actually
Jay
Right...checked the idle switch, replaced the sensor and the thing is STILL idling at 2000 RPM....
Heres a question. I have noticed that the fan on the rad isn't coming on when the engine is hot and I ALWAYS have the blinking light on the dash for the temperature.
Are the 2 connected?
I am running out of ideas and it is really starting to get to me now....all I want is for her to run right :(
Jay
Ok after a quick MSN session, we have found that the o'ring seal for the blue temp sender was missing, and that the wiring to the throttle switch has been horribly bodged and is now broken.  Hopefully after these bits are fixed we should be on the road to recovery ;)
Thanks for all your help....traced back the wires and found a REALLY dodgy connection....replaced them with bullets for now but it has done the trick.....on to the next problem.......:)
Offline Organisys
  • Old and Slow...
those pesky throttle switches and their wiring! Grrrrrrrrrrrrr!
 :grin:
Veedubgt18v
If I recall ,the wires to the idle switch on the throttle body can sometimes break and that can cause excessive idle speeds :undecided:
this makes your idle 'bounce' up and down not idle high i know cos this happened to me
Offline GTI EDITION (aka LTD)
But Veedub8v am I correct in thinking that broken wires were("horribly bodged now broken") and was (at the very lease partly) the cause judging from what Rubjohnny said/posted ??  :huh:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Problem not quite solved but nearly there, she still wants to idle high but now it is only sometimes.....New switches on their way courtesy of RubJonny....Cheers mate :)
Veedubgt18v
yes definately digifant is surprisingly fickle and sensitive to things like that it definatley wont have been doing you any favours lol!
