Author Topic: Rear Suspension Refresh  (Read 437 times)
Offline solares
« on: 06 October 2026, 06:28 »
My 2017 Sport has 130k miles. I did the front Superpro LCA and it drives great. I'm debating should I refresh the back? The bushings look fine and I'm not getting much info if I should replace them at a certain milage. I'm thinking of getting the Superpro upper rear control/camber and the rest OEM. Should I replace that along with the toe links and trailing arms at the same time so I can do the alignment after? This is a daily with no track time, so any feedback would be appreciated. Thanks,
