Author Topic: Mk4 golf gti agu electrical issue  (Read 1623 times)
Offline Jamiebain1981
« on: 19 March 2014, 18:51 »
Got back from work today went to go out car struggled to start rev counter jumps all over the place fuel relay is clicking really fast fuel pump is going on and off injectors are going on and off throttle body clicking coils sparking once I get car started takes a while it runs fine anyone know what could be the problem
Offline mike1990
Re: Mk4 golf gti agu electrical issue
« Reply #1 on: 19 March 2014, 18:55 »
Vacuum leak?
« Reply #2 on: 19 March 2014, 19:01 »
It's doing all that before cars even started as soon as I turn ignition on to second click
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 19 March 2014, 20:13 »
Dodgy ecu or fuel pump relay or crank sensor
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #4 on: 19 March 2014, 21:06 »
I've tried fuel relay and unplugged crank sensor is there anyway off testing ecu if I get it plugged in will it show a fault code if it's ecu
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 19 March 2014, 21:10 »
afaik if you connect up to vag com and there is an ecu fault it should flag it up
2000 Mkiv GTi 1.8T AGU
« Reply #6 on: 19 March 2014, 21:30 »
Ok will find someone to hook it up for me and see what happens
« Reply #7 on: 20 March 2014, 15:24 »
No communication when trying to connect to ecu and car takes ages to start now and cuts out
Offline james2
  • No scammers please.
« Reply #8 on: 20 March 2014, 17:00 »
I would check the battery out first and its connected tight. My old xr2i did this once, turn out to be the battery was very weak so i replaced it.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 20 March 2014, 17:45 »
If its not connecting then i would check the ecu fuse. My mate had same problem and the diagnostics wouldnt connect turned out that a fuse poped
*****MK4 GTI T*****
