Author Topic: r-techs ss k03s tip  (Read 1927 times)
Offline sharki786
  • GOT BOOST??
r-techs ss k03s tip
« on: 19 March 2014, 12:33 »
I picked one up from a guy on fb. Anyway i just had a good look at it and this has 4 ports on the air filter side, 1 for the dv, 1 for the hockey puck thing & 1 for a vac line & another one for?
Mine is the agu so i know i can block the other port off with a bolt or a cap if i can find one.
now main problem is that on my forge the tip has a metal bit on it by the turbo side this is were a tube went to. Now this r-tech tip dont have the metal bit for the pioe to connect. Were could i get one from?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline rfn_hodgson
Re: r-techs ss k03s tip
« Reply #1 on: 19 March 2014, 13:14 »
Ok so
Hokey puk
Recirc valve
N75
And vac line to under inlet manifold
Think that's right bud
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 19 March 2014, 20:16 »
Thats 4 ports/holes. This has 5 its from a octavia that had a k03s. Defo an extra port. I know theres a vac pine right by the turbo for the tip but there is 4 ports at the top. I will defo need to check with my forge one. Also were can i get a metal joiner/connector thingy for the tip? This is right at the bottom were the tip joins onto the turbo a vac line goes to it. Il try and tet a pic up of it.
*****MK4 GTI T*****
Offline benmanc
« Reply #3 on: 19 March 2014, 20:49 »
Is that what people put the mini air filter on?
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 19 March 2014, 20:54 »
i dont know my man
anyway this is the bit circled in red
*****MK4 GTI T*****
Offline rockmonkey69
« Reply #5 on: 19 March 2014, 22:18 »
i dont know my man
The thing people put the little filter on is the intake for the secondary air injection, the circled item is part of the emissions recirculation crap from charcoal canister.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 20 March 2014, 01:36 »
i dont know my man
i know a pipe goes onto that but i need the metal bit as the rtech one dont have the metal bit for the pipe to connect to it. Its like an adaptor for it.
*****MK4 GTI T*****
« Reply #7 on: 20 March 2014, 07:44 »
Might be able to pick up 3mm ID alloy tubing from eBay for not much, some sellers do swaged ends too
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 20 March 2014, 08:57 »
Brilliant mate.
thanks for that.
*****MK4 GTI T*****
