Author Topic: Cud someone check this filter?  (Read 1787 times)
Offline Kelvmelv
« on: 18 March 2014, 21:26 »
I've been reading posts about buying the s2k filter and reducer which I was about to order of eBay when I can across this, eBay item number 390707015893 has any one ever used oneon the gti?
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Re: Cud someone check this filter?
« Reply #1 on: 18 March 2014, 23:04 »
- id go for the s2000 seems to be proving quite popular and wont do any harm and has been known to get good results
http://www.ebay.co.uk/itm/291063759370?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Offline Scott D
« Reply #2 on: 18 March 2014, 23:52 »
Got the same filter from that seller - next day delivery and looks miles better than the green & yellow colored offerings
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline benmanc
« Reply #3 on: 19 March 2014, 06:59 »
Are these direct fit?
Offline Dalo Harkin
« Reply #4 on: 19 March 2014, 08:27 »
I got mine from Euro Car Parts for about £15 and when I unboxed it, it was the red and black.
One thing to note from what I can remember was the green and white ones are non oiled and the red/black seem to come oiled.  :wink:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 19 March 2014, 10:31 »
Here go to euro and quote this number 50260019J this is for the s2k filter and give them discount code pat30 (30% off) but you need to spend a minimum of i dont know. Lols
hope that helps. Make sure its not oiled!!!
p.s comes to £13.02 with discount code pat30
*****MK3 Anniversary*****
*****MK4 GTI T*****
  • Mk4 1.8t AUM
« Reply #6 on: 19 March 2014, 12:09 »
is this the Green filter?
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 19 March 2014, 12:29 »
Ye it is green. But unfortunally its not in the discount. You could buy other things for your car and then add the discount code in and it will work
*****MK4 GTI T*****
