Author Topic: urgent help needed, overheating badly  (Read 4397 times)
Offline Khare
  • The bear that khares
Re: urgent help needed, overheating badly
« Reply #20 on: 12 December 2010, 22:52 »
I wouldn't drive with the cap off either. As Ben said, it needs pressure to work properly otherwise it'll cause bigger problems.
Offline justin3779
« Reply #21 on: 12 December 2010, 22:58 »
just had a thought, when i took the car in to have the clutch done the guy said that there has some bult up of white stuff on the coolant pipe that attaches to the front of the block by the spark plugs so he cleaned it all off and i noticed steam coming from there there when it overheats so colud that be causing all the problems ??? if it boils over when it loses pressure........
Offline Deano2711
  • 1992 VR6
« Reply #22 on: 12 December 2010, 23:01 »
Read my earlier post Mate about mine overheating when I bought it due to a pin hole in the top hose.  :wink:  Sounds like an air lock to me so I would revert right back to Page 1 for the guide on how to get rid of an air lock.
Offline Ben Lessani
« Reply #23 on: 12 December 2010, 23:34 »
If there is a genuine leak, then you can't remove an airlock until the leak is fixed.
Run it up to temp, pop the bonnet and look for your leak, doing anything else is futile.
Offline danny_p
« Reply #24 on: 13 December 2010, 00:16 »
if its getting that hot that quick,   the problem is more than a leack,   remove the small pipe that feed into the coolant resovor,  fill coolant resovor, start engine an rev.   there shoudl be a good flow of coolant out of said pipe.   if not remomove the waterpump and check to see if the inpeller is still on the end of the shaft and has it's blades still intact.   it probobly dosent.      you will also need to fit a new thermostat they don't like being cooked and tend to lock open
all the VW's have gone bar 1.
