Author Topic: GOLF MK4 AIRBAG LIGHT FAULT QUESTON  (Read 4173 times)
Offline luke300586
« on: 14 May 2013, 20:47 »
My mk4 TDI has just failed its mot on a fault with the SRS airbag light,
When i turn the ignition on the light(amber light - person on a chair with the airbag deployed) stays on for a couple of seconds then flashes a few times
Does anyone know what this fault could be?
Thanks in advance
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: GOLF MK4 AIRBAG LIGHT FAULT QUESTON
« Reply #1 on: 14 May 2013, 21:03 »
It could be the seats or the steering wheel airbag, you need to get it scanned with a proper version of VAG COM to find out where to start. The seats are usually the plug getting dislodged when moving the seats or someone shoving their feet too far under
Offline hardmonkeys
« Reply #2 on: 14 May 2013, 21:05 »
Mine flashed aswell...my fault was the passenger airbag was deactivated...this can be reactivated via VAGCOM...I reactivated mine. Are you anywhere near Dorset...I can check for you if you are.
« Last Edit: 14 May 2013, 21:07 by hardmonkeys »
'05 VW Golf Mk V GT TDI Laser Blue
'98 VW Golf Mk IV GTi Black
'97 VW Golf Mk III GTi
'58 VW Golf Mk V GT Sport TDI Steel Grey
'10 Audi A4 B8 SE Multitronic
'00 VW Golf Mk III.V Cabrio
'12 Audi A5 S Line Black Edition
'03 VW Golf V6 4motion
MK3.5 Cabrio 2.0 8v Automatic to 2.0 16v Manual Conversion Project
http://www.golfgtiforum.co.uk/index.php?topic=272728.
www.dorsetautorestore.co.uk
jamie16v
« Reply #3 on: 14 May 2013, 21:33 »
i would consider taking it back to the mot centre and explain to them that its not a fault. the light doesnt stay on, it just flashes a few times.. it`s deactivated because you had a rear facing baby seat in the front  :wink:
or just reactivate it with vag-com.
« Reply #4 on: 14 May 2013, 21:36 »
^^Spot on, it is not staying on so should pass.
