Author Topic: help - digital odometer and clock inop  (Read 1113 times)
Offline D Squared
« on: 19 January 2013, 19:27 »
on a friends mk4 Golf, the digital displays for the clock and the mileometer/odometer does not work...any ideas? fus perhaps?
DD
MK3-MK5- Now MK7 GTi
Offline Kelvin1977
Re: help - digital odometer and clock inop
« Reply #1 on: 19 January 2013, 21:22 »
Checked connection the back? Check for damage on the circuit board
Offline D Squared
« Reply #2 on: 20 January 2013, 10:59 »
do you think that's all it can be? damaged or broken circuit/dodgy connection? are they linked in anyway? same connector etc?
Offline dom
  • Back in a Mk4
« Reply #3 on: 20 January 2013, 11:06 »
Pretty sure it's.a.common problem with clocks. I'd guess a new set are needed.
Offline itavaltalainen
« Reply #4 on: 20 January 2013, 11:51 »
check the pcb for cold solder spots, resolder. might also be a problem with voltage reg.... so measure it's in- and output voltage.
Offline D Squared
« Reply #5 on: 20 January 2013, 19:23 »
hmm ok thanks guys...
