Author Topic: gti electrical problem  (Read 1037 times)
Offline sam1990
« on: 20 October 2012, 15:49 »
basically i have all the symptoms of a faulty ignition switch or a blown f21 fuse BUT.. the ignition switch is fine and when i put a fuse in the f21 slot it turns the ignition on :/ so basically somewhere along the lines the ignition live must have been connected to the permanent live but i cant find it anywhere?? is there anything alse that can go wrong to cause this? like fuel pump or central locking pump or anything?? could the ecu be at fault?? im just really stuck now so any help would be really appreciated  cheers guys
