Author Topic: abs faults  (Read 1359 times)
Offline brett
abs faults
« on: 22 August 2012, 16:27 »
alrite all just a quick question.I replaced both my front abs sensors fri as drivers side was showing up a fault ,but have replaced them cleared the fault and its still coming up ,and also get a random sporadic abs pump out of tolerance fault ,any help or ideas would be appreciated ,cheers brett
Offline GOLF-MK3-GTI
Re: abs faults
« Reply #1 on: 22 August 2012, 18:12 »
Check the clip/wiring of the abs sensor, I had this fault an upon removal I noticed the wire was split causing it to show up abs light, I had to chop and get a new clip from scrappy and join it together
Offline brett
Re: abs faults
« Reply #2 on: 22 August 2012, 18:39 »
cheers mate will have a look ,did look ok when changed it but will double check just to be certain
Offline Screech16v
  • MK3 20vt AGU
Re: abs faults
« Reply #3 on: 22 August 2012, 18:50 »
Also check the plug to the pump.
Offline brett
Re: abs faults
« Reply #4 on: 22 August 2012, 19:28 »
will do mate ,thought you might have some ideas lol
Offline Screech16v
  • MK3 20vt AGU
Re: abs faults
« Reply #5 on: 22 August 2012, 19:47 »
lol Yeah,had some grief with it in the past mate but lovin it at the mo ,buzz every time that little orange light goes out,hope ya sort it.
