Author Topic: Rear washer jet again  (Read 1034 times)
Offline cooki
  • 1.8T AUM
« on: 22 July 2012, 19:52 »
Right guys picked my new 1.8T up today and the rear wash jet isn't working.its leaving a damp patch in the roof lining. So unclip ed everything to take a look and I have found a black hose loose witch the water just poors out of. There are no other tubes for it to connect to.
Do u think somebody has removed the piece of Jose that should go from here to the actual washer jet or something.
Any help apretiated.
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline Ray_Ray280
Re: Rear washer jet again
« Reply #1 on: 22 July 2012, 20:04 »
i would just de-wiper the rear (looks 10000000000% better imo) and the tube from the washer bottle to the rear either dis connect it or remove it
Offline harlemex
« Reply #2 on: 22 July 2012, 22:44 »
I think a pic would help here, but it should clip straight on to the nozzle on the back of the wiper motor.
Offline cooki
  • 1.8T AUM
« Reply #3 on: 22 July 2012, 22:53 »
Thanks for the replys guys. After alot more searching On here I found that Wer mine was disconnected it should be atatched to a 90 degree bend connector  witch I found in the end so all is fine. Thanks again :) :)
