Author Topic: R32 vents into a gti?  (Read 1742 times)
Offline Scott-R
  • GoT BoosT!
« on: 04 June 2012, 21:42 »
Has anyone fitted r32 vents to a gti? Why doest the switch on driver side fit properly?
Golf GTI ... What else would you have?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: R32 vents into a gti?
« Reply #1 on: 04 June 2012, 22:08 »
interior vents? Mine fit perfectly :huh:
Offline cullygti
« Reply #2 on: 04 June 2012, 22:18 »
i thought they were the same as its the same dash  :huh:
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #3 on: 04 June 2012, 22:19 »
Are they not just the same as Bora vents as in different slats and they light up if so they will fit fine.
Golf Gti
Offline Scott-R
  • GoT BoosT!
« Reply #4 on: 04 June 2012, 22:21 »
My right hand side wont sit flush! No clips are broken its like theres something catching behind it.. Will look again tomorrow!
Offline dom
  • Back in a Mk4
« Reply #5 on: 04 June 2012, 22:24 »
There is a little metal clip on either side of the switch, they sometimes slide off when your removing your old switch. Take the switch back out and check to see if yours is still in there, that would stop it from sitting flush :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 05 June 2012, 09:36 »
R32 and Bora vents are the same, the R32 ones don't light up though
