Author Topic: psssss noise  (Read 1134 times)
Offline monty9120
psssss noise
« on: 01 June 2012, 21:33 »
hi all. when i change gear i got a whoosh sound. i have changed the dv to a forge. the car is running 10 times better. the noise seems to be coming from around the front manifold area. i have checked all pipes i can and there fine.
i have heard a small whoosh noise is normal. would it come from this area. i do get a tiny hesitation every now and again but it could be possible turbo lag
thanks
Offline Toby
  • Car - less
Re: psssss noise
« Reply #1 on: 01 June 2012, 21:50 »
agu?
post a pic of your forge one?
checked for boost leak's?
Currently down under
Offline JimBR
Re: psssss noise
« Reply #2 on: 01 June 2012, 23:47 »
Not a forge split-r is it?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: psssss noise
« Reply #3 on: 02 June 2012, 10:54 »
need to know engine code really. Could be possible breather leak if it's down in that area
Offline monty9120
Re: psssss noise
« Reply #4 on: 02 June 2012, 13:39 »
im sure its an agu. its a forge 007 i think. with a yellow spring
