Author Topic: Door hinges ??  (Read 967 times)
Offline madhead1987
Door hinges ??
« on: 06 July 2012, 10:42 »
Ez everyone , doors seamed to have dropped I've herd this Is common on the three doors ? Is there a fix or new hinges ??
Is there a sticky on tho ?
Thanks reece
Offline wolfie1981
Re: Door hinges ??
« Reply #1 on: 06 July 2012, 10:52 »
i would like to know this two :smiley:
Offline harlemex
Re: Door hinges ??
« Reply #2 on: 06 July 2012, 12:43 »
My five door front doors creek quite bad, same issue I think.
Offline BarryMKIV
Re: Door hinges ??
« Reply #3 on: 06 July 2012, 14:22 »
My good friend WD40 solved my creaking issues. Drowned the hinges and gave the door a few good swings until it soaked in.
Any decent bodyshop should be able to sort the dropping issue. It's quite common with 3DRs
25th Anniversary GTI 1.8T No. 0441
Offline madhead1987
Re: Door hinges ??
« Reply #4 on: 06 July 2012, 14:35 »
I thought it was common just coudnt find a sticky on it might be worth doing one I've spoke to lads at Vw body shop theve said take the door actually of then the m10 bolts on the a post easier to get to theres one behind the trim also ie two bolts holding each hinge loosen them then nip one up , put door back on so slight movement in hinge but not to much , then align , then nip um up proper if the hinges have failed stick a socket in the gap and give the door a couple of tweaks
I am not responsible for anything that goes wrong just post some Info that I've been told
Offline daz veedub
  • Operation 1.8t bolf
Re: Door hinges ??
« Reply #5 on: 06 July 2012, 18:02 »
try jacking up the door see if that helps put a thick cloth on the jack to save marking ya door
