Author Topic: coolent temp sensor  (Read 833 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
coolent temp sensor
« on: 18 December 2011, 11:00 »
A few weeks ago I had a new silicone tip fitted because the old factory one had a rip in it. i also had the car serviced and all was running fine, the power was back and the 17705 code had not come back either. But, now I got another code 17704, which is the coolent temp sensor I do believe, and now I also have the 17705 code back and there is a loss of power, as it doesn't drive like a remapped car anymore. I have the 1.8t aum gti
Can the 17704 code also cause the 17705 code to reapear?
I only changed the coolent temp sensor about 8 months ago, so I am guessing it has gone again. If I replace it again will this also sort the 17705 code out?
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
