Author Topic: Suction Jet Pump?  (Read 1415 times)
Offline tonyg123
Suction Jet Pump?
« on: 14 December 2011, 13:36 »
hello Peeps,
Need some help big style here, Appreciate your time if you can.
Fault code appeared on the trusty Golf today (17705) reading into this online. Looks like I need to replace a Suction Jet Pump?  trouble is after speaking with the stealers, they say they cant find anything under this name. I quoted an american part number and the only thing they can relate it to will cost nearly £60!!!   :sick:
Anybody know if it is this part that needs to be replaced and if so, can I get it anywhere?
Cars a 1.8t AUM 52 reg, running a little rough.
Cheers Guys!
Offline Big Tone
Re: Suction Jet Pump?
« Reply #1 on: 14 December 2011, 15:29 »
17705 is boost leak, could be loads of places, including the sjp.
Need to pressure test it really.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline tonyg123
« Reply #2 on: 14 December 2011, 15:47 »
Cheers Big Tone.  Will try and book one in over the weekend.
Fingers crossed it will be a simple fix?!
Offline richw911
« Reply #3 on: 14 December 2011, 17:14 »
Dont hold your breath it is a nightmare to find  :cry:
 As said get a smoke test done - check the pancake pipe. Is it running the standard recirculating valve? These are prone to crack and cause a leak  :smiley:
Offline tonyg123
« Reply #4 on: 14 December 2011, 17:16 »
All Standard..., Only had it a short time. Was going to get a re map in the new year. So lucky this has come now!
I will have a look at the DV this weekend. Are there any tell tale signs?
Offline Big Tone
« Reply #5 on: 14 December 2011, 17:20 »
Worthwhile popping the bonnet and having a look yourself first.
But yeah, 17705 is fun to eliminate. Good luck.
Offline richw911
« Reply #6 on: 14 December 2011, 22:18 »
Check the small vacuum pipe on top of the recirculating valve as these go brittle and snap  :smiley:
Offline tonyg123
« Reply #7 on: 15 December 2011, 16:09 »
Cheers Guys, really appreciate your time :)
Offline richw911
« Reply #8 on: 15 December 2011, 16:23 »
No worries let us know how you get on  :cool:
Offline brianpologti
« Reply #9 on: 15 December 2011, 21:11 »
Where in Herts you based
