Author Topic: Mk3 16v intermittent cut out,no power-abf engine  (Read 1762 times)
Offline spence
« on: 29 October 2011, 12:31 »
Ok,can someone offer some advise.
problem-driving along,come to junction or round about,change down gear,apply the throttle and there is nothing there,keep it on and it suddenly kicks in,keep throttle down and is fine,lift throttle and put down again no power.
stop at lights,go to pull away engine cuts out,starts straight away,after that it can go a day or so with no problem?
rotor arm,dizzy cap,ignition coil,leads,plugs all good
fuel pump solenoid changed
Offline dragongreengolfgti
  • my golf gti mk3
Re: Mk3 16v intermittent cut out,no power-abf engine
« Reply #1 on: 29 October 2011, 14:09 »
Do all of this in order of cheapness  :smiley:
1.clean the throttle body
2.check all vacum hoses
3.check your lambda sensor
4. get a vag com test done
5.check small hose to ecu from throttle body
6.Check all earth points on engine and under battery tray
7. check battery it self
8. Try another coil
9. a good service plugs,leads check distributor cap and rotor arm.
10. REplace ecu and fuel relay no. 30 and 167
Hope this helps
Offline spence
« Reply #2 on: 29 October 2011, 15:23 »
ok nice one
I have just renewed the pipe from ecu,only thing i have not done on that list is sensor and earth points,will check those out.
cheers for that
Offline spence
« Reply #3 on: 29 October 2011, 16:40 »
can you test the lambda sensors on the car?
  • my golf gti mk3
« Reply #4 on: 30 October 2011, 20:39 »
yes but i've never done it so not sure how there should be a guide on here maybe in maintenance section or search for something like abf lambda sensor readings im sure you can find what you need on the www  :smiley:
