Author Topic: How much play should there be in vr6 brake pedal?  (Read 1054 times)
Offline stevolution
« on: 13 September 2011, 10:52 »
I got my mechanic to replace my pads and change my brake fluid.
I thought my pedal would be slightly firmer as I've always felt there's quite a lot of travel, if anything it's worse. The brakes are really good when they connect but just a little too spongey.
Will I manage to bleed them through a set of audi tt 6 spoke ronals?
Offline gasketface
Re: How much play should there be in vr6 brake pedal?
« Reply #1 on: 13 September 2011, 10:56 »
Bleed them through the back.If they have'nt been bled for a while i would be taking the wheels off one at a time and heating up the bleed nipples before i undid them.If you snap one you got yourself in a big hole  :smiley:.
Gunson eezibleed would be handy.
Offline Len
« Reply #2 on: 13 September 2011, 12:55 »
Take it back to your mechanic and make him do the job properly!
www.sas.org.uk
www.the-ace.org.uk
Offline AudiA8Quattro
« Reply #3 on: 13 September 2011, 13:21 »
Have you given enough time for the pads to bed in? usually need about 100 miles.
