Author Topic: Couple of Questions  (Read 1003 times)
Offline WadGTI
  • Golf GTI'er
Couple of Questions
« on: 25 August 2011, 19:05 »
Hi Folks,
Got a couple of questions, if anyone can help me here.
I replaced the fuel regulator pipe (braided hose sits above the head) with samco 3mm hose. I think the orginial hose was 3.5mm to 4mm. The old hose was in bad condition and it was all I had - should this be ok? the car idles ok, just it seems it lost a wee pit of power (could just me me lol - mind you there isnt much power too loose).
Got a bit of squeeking from the back of the car - boot area. Its not the suspesion or bushes, think its the inside rear trim - anyone had this issue before?...Dont want to rip out and rebuild the full thing - they may be a problematic area.
I have checked all breathers and vaccum hoses and there all good with no splits. Sometimes when I start it from cold, there is a petrol smell in the cabin. The choke kicks in for a few mins then idles ok. Any ideas?
Finally, has anyone got any pics on oil breather setups. Got a kit, but couldnt find really any pictures of other mk3's with it installed. Just wanted to see what theres looked like.
Thanks again - good forum, with good people :smiley:
Offline Screech16v
  • MK3 20vt AGU
Re: Couple of Questions
« Reply #1 on: 25 August 2011, 19:35 »
SQEAK SQEAK SQEAK so annoying, i had one similar to what you have described,took me ages to locate it ,try going for a little drive with the rear seats down,it was the back of the seat rubbing on the plastic trim on mine  :smiley:
Offline WadGTI
  • Golf GTI'er
« Reply #2 on: 26 August 2011, 13:16 »
Thanks for this...I will try it out.
Just recieved catch tank today in the post. However it s a 3 port. Basically a cylinder with 2 ports (port 1+2) on one end and the one port on the opposite end(port 3).
Am I correct in saying that the oil breat from the inlet manifold should connect into port 1 of 2 and the bread that goes into the air intake (pipe located up from the the MAF) should go into port 2 of 2.
Port 3 still a small air filter on it?...I have read these can be used a return flows to the sump as well.
I may have this wrong, but if the above is the case, what direction should I have the catch tank siting?...If port 3 points towards the ground, woldnt this just leak out of the filter??(gravity).
Thanks again
Offline WadGTI
  • Golf GTI'er
« Reply #3 on: 26 August 2011, 13:20 »
http://www.ebay.co.uk/itm/110726890791
Thats the tank there.
Thanks
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 26 August 2011, 20:31 »
Why are you putting bread in your intake  LOL :laugh:
How come your putting a catch tank on dude  :smiley:
Offline mellow yellow
  • A Driffield Dubber!
« Reply #5 on: 26 August 2011, 21:34 »
lol had this the other week, got all the way to work and realised the boot wasnt shut properly  :lipsrsealed: worst thing is i hadnt been in the boot for a bit so must have been open for a few days..... doh!!
Offline WadGTI
  • Golf GTI'er
« Reply #6 on: 26 August 2011, 23:39 »
Am not. That just came with the kit. Looks like it was a universal kit.
A few reasons... Mainly stop shi! Going back into the engine, stop the inlet mani cligging as i cleaned it last week and it covered in gunk. ???
