Author Topic: re sunroof  (Read 874 times)
Offline mart25
re sunroof
« on: 21 July 2011, 09:33 »
last night my sunroof jammed  slightly open,the motor is trying to work,but wont close is there a manual device for closing it
thanks mart
Offline mad4vws
Re: re sunroof
« Reply #1 on: 21 July 2011, 09:37 »
which golf have you got mk2 or mk3 , on mk3 there is a allen key which you can use to manually close the sunroof on mk2 is on the winder only. :cool: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline LowlifeDubber
Re: re sunroof
« Reply #2 on: 21 July 2011, 11:23 »
As this is in the mk3 section id throw it out there that you have a mk3 :grin:
Like matey said if you pull back the square plastic cover next to your sunroof switch/interior light,you will find an allen key in the shape of an s.
You will also see a manual overide switch on the actual motor.Turn this 90degrees then stick your allen key in the hole and start turning.
If you find it is still not going back look up at the sunroof from inside and you will see a plastic cover,covering the runner on either side.Unclip it and slide it back into the roof(not too far as it is a b!tch to get back) then as your winding the window home look at the shiny silver claw on either side.Gentyl coax this the way you want it to go(to the back of the car to close) while turning the handle to get your sunroof back to the home position. :smiley:
Offline mart25
Re: re sunroof
« Reply #3 on: 21 July 2011, 21:29 »
thanks for your advice all sorted  :smiley:
Re: re sunroof
« Reply #4 on: 22 July 2011, 15:05 »
What did you do? :grin:
