Author Topic: MPG on dash wont change....  (Read 872 times)
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« on: 31 August 2011, 12:46 »
Hi all,
Noticed the last couple of days the car is stuck between 33.2 and 33.9 MPG on a run.
The car is not doing that as i am using the same amount of fuel as normal per day and is running fine.
So is there a way of resetting the MPG on the dash?
Only thing I have done differently recently is used Super Unleaded as I was on fumes and the garage only had that left.
Dan
Offline javalin
Re: MPG on dash wont change....
« Reply #1 on: 31 August 2011, 13:28 »
push slider on right stalk all the way left to reset the "per trip" counter, or all the way to the right for the "per tank" counter.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Seanl
« Reply #2 on: 31 August 2011, 13:29 »
Yeah move the slider on to to the position marked 0. If your in position 2 it will be totalled since last reset anyway, so if its been a while, its not gonna move much.  :wink:
Offline MK3 Menace
« Reply #3 on: 31 August 2011, 14:13 »
Cheers boys! Ill go give it a try now!
