Author Topic: Any other topmounts fit the mk2?  (Read 3332 times)
Offline richking
Re: Any other topmounts fit the mk2?
« Reply #10 on: 16 July 2011, 11:37 »
VR6 mounts are the same as 16v mounts i asked them to check at main dealer when i bought some for mine (for a mk3 this is)
Offline Mr Blue
« Reply #11 on: 16 July 2011, 22:01 »
nice one ladies :)
So i just need parts 21, 28, 25 and bonus 24?
Offline cняis
« Reply #12 on: 16 July 2011, 23:34 »
IIRC all the later (96 on) mk3 top mounts are identical, 1.4 to 2.8  :smiley:
VeeDubGTI16v
« Reply #13 on: 17 July 2011, 08:23 »
are you running strut n springs or coilovers? if springs you need no 26 as well, but i can't remeber what vehicle you need it from, think its a base spec mk3 (maybe the 4 stud ones) as mk2 and 3 springs are different diameters at the top.
someone will know!
Offline Mr Blue
« Reply #14 on: 17 July 2011, 09:54 »
Running soilovers so i may not need the cups for the mk3 setup :)
Offline weazgti
« Reply #15 on: 17 July 2011, 12:34 »
I stripped some mk3 ones but found that you need the early mk3 spring plate because the later one s are miles too small for the spring.
I did have a thread on here and rubjonny very nicely put the part numbers up.
