Author Topic: Random (possibly niave) questions MK1 Cab  (Read 1850 times)
Offline Mixmasta
« on: 04 April 2005, 13:18 »
Hi all,
Just replaced a rear side light bulb in my car when I noticed that the my other bulb was out, after tapping the outside lens the light came back on. I stripped down the light cluster and connections seem to be really snug and in correctly - I'm panicing thinking that the new suspension i have fitted is too strong/hard and is knackering wires connections etc - anyone had similar probs?
Whilst in there I noticed that my carpet wasn't lying flat, upon investigation i noticed that the knob which you screw down to hold the space saver in place, doesn't go down far enough - this is restricted by the 'tread' on either the male or female side (even if you take the wheel and everything out it still protrudes) - any ideas?
I also found a rather strange but OEM looking item, it's like a large black rubber band with 2 big z clips on it (looks like it's for strapping something down)? any ideas
Electric windows - mine has an after market set of front electric windows but one of the switches seems to be cutting out probably due to a thermal cut out, so I think that i need to reaplce the whole lot. After seeing later models (MK1 Rivage or even upto MK3 GTi's) I would like to change the system to an original VW one (albeit not for my car), can anyone suggest which is the best overall replacement package for this, along with any pitfalls i may face.
Thanks guys!!!!!
Mix
Offline carrie
  • i can see into your soul and its not good
Re: Random (possibly niave) questions MK1 Cab
« Reply #1 on: 04 April 2005, 13:51 »
i assume you are putting the wheel in front facing down.
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline Mixmasta
« Reply #2 on: 04 April 2005, 16:55 »
Hi Carrie,
I am indeed, as mentioned it doesn't screw down far enough even with everything out of the boot - I have just unscrewed it at the minute till I can figure out whats what.
Thanks fer ya help
Mix
Offline black_cabbie
  • If they don't have a golf in heaven I am not going
« Reply #3 on: 08 April 2005, 07:01 »
The original VW loom has a control module which looks like that.
If you are interested I have one for sale with loom and oriignal VW switches that illuminate blue.
1.8L 8V Digifart, AMS chip, Kent 270 camshaft, TT Adjustable Cam Gear, Supersprint Header with supersprint catless system, BMW AFM, Adjustable FPR. G60 Green 23lb injectors coming soon.... =)
