Author Topic: PLEASE CAN ANY ONE HELP ME ???????  (Read 826 times)
Offline smithymk2rs
« on: 07 February 2011, 21:11 »
hi ya guys im going through some trouble bleeding the brakes ive just pt a s3 eng in a mk3 so ive just fitted a vr6 abs unit an master cylinder bt im not getting any fluid or air out of any of the brake nipples there all clear an not blocked im useing a pressure bleeder i think ive pt the brake pipes on wrong 2 the abs unit if any one can help an tell me what pipe goes were would defo help me
Offline trackday
Re: PLEASE CAN ANY ONE HELP ME ???????
« Reply #1 on: 07 February 2011, 21:39 »
try bleeding it with the ignition on if still nothing let me no and will have a look at my vr6 mk3 and let you no what pipes go where
Spec- Sounds awesome 2800CC VR6 200BHP Remapped with 7300 rev limit. Kent cams, cold air carbon intake kit. Forged pistons,power boost valve,6 branch manifold, de-cat pipe and full powerflow exhaust system.Grooved discs with red stuff pads. Gaz Gold fully adjustable suspension, 3.8 camber at front.
Full race cage, Momo steering wheel and corbeau race seats with four point harness. Fire extinguisher and 4.26 final drive conversion
Offline smithymk2rs
« Reply #2 on: 08 February 2011, 10:45 »
ive have tried anstill nothing so ifu could tell me whatpipes go were would be great many thanx  :grin:
Offline trackday
« Reply #3 on: 08 February 2011, 20:13 »
hopefully its the same system,from the electrical sensor end pipe 1 goes to master cylinder front pipe 2 n/s/f pipe 3 o/s/r pipe 4 n/s/r pipe 5 o/s/f pipe 6 master cylinder rear dont forget to bleed the master as well check you have got fluid comin out of the nipple when pedal depressed on the master if no fluid the master is probley goosed norm fook up if been standing empty hope this helps
Offline smithymk2rs
« Reply #4 on: 08 February 2011, 20:39 »
sound mate ur a star  :wink: ill give that ago 2 moz an hopefully she will be out to play  :grin:
