Probably a stupid question, but if I just put 20mm spacers on the back and none on the front would that cause any issues?
Will be fine mate.. Why not push the fronts out a tad as well ??
Dim problem with spacers only the rear
Quote from: Rhyso on 11 January 2011, 11:00Dim problem with spacers only the rearDim problem?
Quote from: tech1889 on 11 January 2011, 10:36Will be fine mate.. Why not push the fronts out a tad as well ??Yeah I might do, the spacers are £50 and money is tight so wanna try the back first to see how it looks. Then next month maybe get 10mm fronts.
