The garage
Plenum Chamber
Topic: Plenum Chamber (Read 1984 times)
TobyB
Just got here
Plenum Chamber
09 December 2010, 01:10 »
Was advised last service that I will need Plenum chamber cleaned, how important is this and what is the likely cost? Golf Gti MKV 2007 with 21k
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Re: Plenum Chamber
09 December 2010, 08:28 »
Er... why would need the plenum chamber cleaned? That's what the air filter is for...
Are you sure, the garage/dealer is not trying to have you on?
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
arwl1976
Just got here
Re: Plenum Chamber
10 December 2010, 17:00 »
what the hell you got in there? mines just got leaves and bugs in it, easy to clean out just blow it out with an air hose
TobyB
Just got here
Re: Plenum Chamber
10 December 2010, 18:57 »
thanks, sounds like something that should be done when it gets a full service next week, if they claim its extra i'll do it myself.
Agreeable Slick
Global Moderator
Unit
Re: Plenum Chamber
10 December 2010, 20:29 »
The plenum chamber shouldn't have anything in it.
The air box is a different matter, however, it is just a case of removing the bottom part of the airbox and cleaning that out.
I made this : ->
danny_p
Forum addict
Re: Plenum Chamber
12 December 2010, 02:10 »
some diesels soot the inlet maniolds up really bad over time. about shoudn't have at 21k
had dealings with a lot of coked up manifolds on older diesels thanksk to the EGR easyest way to clen them is fire
all the VW's have gone bar 1.
The garage
Plenum Chamber
